Piplodocus
Hello!
Just want to know about the "Send PCs" options...
Does "Send PCs" just:
* turn on/off the option to send PCs with each preset by adding it to the device PCs/checkboxes at the top of each preset?
(but any IA buttons programmed with PCs will still send)
* Or does it also disable any PCs being sent to that device on preset changes if there are IA buttons which send PCs regardless of the saved state of those buttons (but once in the preset you can then use IA buttons which send PCs)?
* Or does it stop any PCs being sent to it ever (i.e. won't offer the option to change PC at the top of the preset + will disable any IA buttons that send PCs on preset changes + will disable/discard all IA button messages that send PCs to it all the time ever - so you cannot change PC ever)
Instead of controlling my MIDI controlled amp with a PC for each preset, I have programmed the first 4 MIDI presets of it with each of the 4 channels. I can then have an amps page with IA buttons for each PC so I effectively have amp channel programmed as an exclusive group. I can then save the button state (amp channel) with each preset in the PBC. But I'm not sure if I should be turning send PCs off to stop any chance of me sending 2 conflicting PCs, or if that stops sending any and my amp would stop switching channels.
