Effect Gizmo question
Loge55
Hello, it’s my first post here but I’m finally hooking up my rack build and have a question. The diagram shows if your running two amp to plug one amp into the the 9 N/C and amp 2 into the 10 N/C. The diagram only shows for 8 pedals and I’m planning to run 12, but two of them through the midi, so do I just run pedals 9 and 10 in the 11 and and 12 after the second amp? Or can I only run 8 pedals? Will it mess with a delay If I run it in the 11?
If you're planning on running all pedals in front of both amps, move the amp connections to loops 11 and 12, and put the additional pedals in loops 9 and 10. Be sure to connect CS Out to In 9, Out 9 to In 10, Out 10 to In 11 and Out 11 to In 12, those connections are not made internally.
Thank you very much!
