Hi guys,
I hope you are all well. I managed to get myself and old V2 Triaxis a few weeks back and its been covered to 240v to work over here in the UK. Sound wise everything is working great, modes work, and the controls work etc. I'm having some issues programming with the GT and the Axe FX 3.
info first, Axe is set to midi chan 1 and the Triaxis to midi chan 2. There's. a Voes M-Box taking care of the phantom power to the GT and obviously plugged into the midi in out on the Axe. The Axe works fine with the GT without the Triaxis. I then have a 5 pin midi cable plugged in from the Triaxis midi in to the Axe fx midi thru port.
When setup in the GT editor I have the Triaxis setup as a generic midi device and I'm using PC actions to switch the triaxis and then a separate action to toggle the Axe scenes 1-8. I just want to know if I have the Triaxis action setup correctly? Is it just a question of selecting the PC no off to 0 or none and then the PC no on to the the correct no so say 1 for preset 1 on the trixais? Or is that not correct?
I'm not sure if there's an issue with the triaxis itself as sometimes when I switch presets on the GT I get a different PC no comes up on the Triaxis no matter whichever button I hit on the GT or that I've programmed. The shift button on the triaxis doesn't seem, to be working correctly so I'm unable to get into that mode to map the PC no's unfortunately but that doesn't mean I can't select a different preset which doesn't see to be working or it will switch briefly and then go back to the preset I don't want.
It's gotta be something I'm not doing on the Triaxis. I hope that all makes sense.
Can you guys help me out and suggest anything to try?
Many thanks
Paul
Many thanks
Paul
