Questions for my new pedalboard
AK47
Quick question — between the Lehle expression pedal and the ParaEQ + Foxrox Octron 3, which would you choose?
I just received the Empress ParaEQ in a trade, and I have a bit of nostalgia for the Foxrox Octron.
I’m afraid I won’t use the expression pedal often enough to justify its size, and I’m also worried I might not manage to tame that EQ.
The Foxrox Octron had that little bit of grit I couldn’t quite find in the Tripplegraph. Then again, I already have similar sounds in the H90… so is it really reasonable to add it?
Otherwise, I could remove the tuner and use the one in the PBC6, and make room for the ParaEQ instead.
What would you do?
