brain teaser
Victor Vos
Sorry to bother again... I have a real brain teaser, I can't find it...
One of my presets (#27) takes the GT to page 2 where it is set to go to page 1..
The local page (with I can recall by second pressing the preset button) is present at my GT but when I want to edit this local page it is complete empty.
I can't find any differences to all other presets...
  • vix.rjs
Regarding the first issue, you have a hold function on the "filter" button on page 1. It's programmed to go to page 2 when held. It also has Send on Preset Change and Update on Preset Change turned on, and on preset 27, it's turned on. That causes an automatic change to page 2. The fix I recommend is:
- Turn off Send on Preset Change on the button's hold function.
- In Presets, select preset 27, then shift-click on the scenes button to turn off the hold function
Part of the problem is that you can't currently see the on/off state of the hold function when "Show Name" is turned off for that hold function. This is probably something I should fix in the editor. You can turn Show Name on temporarily so you can verify whether the hold function is on or off.
Regarding the second problem, it looks like the second press on a preset button will go to the previously selected page, not the local page.
Oh I missed this hidden one when turning all off... This solved the problem of page 2 appearing with preset 27.
This I don't understand. How do I shift click on what button?
I still don't see what made preset 27 trigger the hold function and where it differs from other presets.
No, it selects page 16
The local page of preset 27 is empty, I can rebuild it, then: solved!
Here's a quick video showing what I mean:
Yes it helps! thank you!
still don't know how it got turned on only in that preset but it no longer does and I rebuilt the local page so I am all happy!
