H90 Dual Mode
I have been searching through the forum, can't get his fixed. I am running the H90 in dual mode. I have the "A" side running out Loop 5 (Insert Cable tested) into 1/2 H90, out 1/2 H90 to Retrun Loop 5 (Insert Cable tested). After Loop 6 (Stereo), Out Stereo, into H90 3/4 out 3/4 to Reverb to end of chain. System runs full stereo just fine with Loop 5 Not engaged. As soon as I engage the Loop 5 it kills one side of the output.
Loop 1-3 Mono
Loop 4 Mono
Insert (Volume using normal TS cable)
Loop 5 Stereo
Loop 6 Stereo›
I have my H90 wired exactly the same way and no issue whatsoever here .. maybe a faulty cable on Loop 6?
Thanks for the reply. Will double check the cables. I can turn loop 6 on without loop 5 and everything works as it should in full stereo. Just something with Loop 5.
I've never used an H90, but does each input / output pair need to be configured as mono or stereo? If so, maybe the first pair is set to mono?
