PBC6x & Micro Line Mixer
AK47
Hello guys !
I am currently working on my new pedalboard.
I would like to run some effects in parallel using the Micro Line Mixer.
I play without an amp (2 Kingsley pedals as preamps and the Tonex as an IR or amp simulator) and I have a few questions:
- Do you think my setup makes sense? I have some doubts about the placement of the Tonex. Can I put it between the PBC and the Micro Line Mixer, or should I place it in loop 4 (which would mean sacrificing a pedal or finding another solution)?
- Should I place the Micro Line Mixer outside the pedalboard and use a splitter (which one would you recommend for this setup)?
- I’m using the Eventide in pre/post mode; do you think its placement is appropriate?
The mix out would go to the Walrus Canvas DI and then to my sound card or mixing desk.
Thanks in advance for all your advice! I’m open to any suggestions to build the best pedalboard possible.
You could certainly do what you've diagrammed and it'll work. Putting the Tonex where you have it will result in the signal from the Tonex going to the dry input of the mixer, but not to the three parallel pedals. This will probably sound a bit weird if the Tonex is your main source of gain.
Since all of the parallel pedals are MIDI compatible, you could move them to a splitter and it would still be fine.
The H9 placement seems fine.
Thank you for your response, and sorry for the delay :)
Here is the 2.0 version of my pedalboard diagram in its final form (well, for now^^).
I just need to find a splitter.
Do you know of any alternatives to the Galaxy Audio one you linked?
I’m in Europe, and they don’t deliver here.
I’ve only found buffered splitters... which are more expensive.
Can we use these models:
Also, if anyone has other splitter models to suggest, I’m all ears!
I've not used any of those splitters, but I'd expect they'd do the job.
The diagram looks ok to me!
Great :))
I found a Galaxy Audio Splitter on eBay :)
Now I just have to order my Micro Line Mixer
