What are the power requirements of the Rack Gizmo?
The Rack Gizmo needs 9 volts AC or 12 volts DC. 9 volts DC will not work! The Rack Gizmo draws a maximum of 550mA (700mA if you have a full stereo Rack Gizmo). These numbers are maximums, measured when all 16 switches are turned on simultaneously. If you're phantom powering a MIDI controller, please remember to add in the power consumption of the controller when determining the total power consumption of the Rack Gizmo.
The connector is a standard BOSS-style barrel connector, 5.5mm x 2.1mm x 9.5mm. Polarity is unimportant.
