Mini Effect Gizmo I - help
painkiller
Hi
i want to connect my Morningstar MC6 MkI with the RJM Gizmo mini Effect VI but it doesnt work.
I have set up the MC6 like on the picture but nothing happens..
What do i wrong?
Thanks you
One issue I see is that the first message is set to send on channel 1, but the second is set to send on channel 2. They should be on the same channel.
And, also verify that the Mini Effect Gizmo's settings are what you expect they are. Both the channel and CC numbers are configurable from the front panel. The manual is attached - see the Setup Mode section.
  • Mini Effect Gizmo Manual.pdf
