Hi Ron and RJM users,
I have just added a MLM to my existing RG-16/Mastermind rig...I have a TC Gmajor 2 and which was previously wired into the serial effects loop on my Boogie MKV head..via the RG-16...I decided to buy the MLM and try and get rid of the tone suck from having the GM2 in a series loop....all works well and tone is much better...It's running on loop 5 ...but I have noticed that I get a small drop in volume/tone when I engage loop 5...as a test I changed all the cables and still got the same results....I then added a Boss Space Echo pedal to loop 6 and found that I don't get the problem with that.
All levels in the global/patches of the GM2 are on full and pro and consumer mode have no effect....not that I would think this would make a difference....it's as if when the GM2 is put in the parallel loop it's affecting the direct pass through signal...I have also tried a different input on the MLM but no change....it's not a major problem more of an irritation! :roll:
Any ideas gratefully received!
Cheers
Paul![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Cheers
Paul
