I'll try that. It could also be a switch configuration setting as well. I found an article on the help section from the RJM website that deals with switches acting strangely. I'll try that later tonight when I get in from work.Maybe try the System Test (hardware menu).
And also a complete wipe of all settings using a USB drive I'll try that too.
How to do a complete wipe of settings
In certain cases, a Mastermind GT will get into a state that makes it impossible to factory reset it or load new settings from the computer. This is a process you can use to get your GT up and running again. You will need a FAT (PC) formatte...
How to fix Mastermind GT buttons that are acting strangely?
Depending on your GT's age, it may come with one of two types of switches. If the GT is set up for the wrong type of switch, you can see odd things happen. For example, buttons will trigger when you release them instead of when you press them. ...
