Piplodocus
Thought I'd post my pedalboard journey over the last decade or so...
So, I recently broke this baby up, cuz it was just too impratical. It went through many revisions and this was it's final state. Absolutely rammed from bottom to top with stuff. 2 FAMC LF Jr+'s. MIDI controlled Voodoo Labs PX-8 (so can instant access anything, but MIDI switches everything next patch), MIDI clock across lots from the DAD Smartclock. Modded the Subdecay pedals with a little opto-isolator to external tap jack so it also taps them so they sync to everything. RJM mini effects gizmo on the right under the Fuzz Probe and MIDIBox, so 13 loops + MIDI switched pedals.
FAMC have disappeared off the face of the earth though, so no updates anymore and the editor doesn't work with Apple Silicon Macs. Tap never worked properly for me and neither did MIDI clock. Hence smartclock. But it was still amazing, but just far too heavy. Was just too big and weighed a ton.
The Delay/Reverb and Mini Amp Gizmo live in the rack. They didn't fit on that board above anymore, can be completely MIDI controlled, and are in the amp's loop, so why run extra long cables back to the board and back? So that's here:
So the cable loom runs from this to the pedalboard and will switch either of the Diezels via MIDI, but RJM MAG switches all the Bogner XTC channels and stuff when using that.
Then when I joined a new band a few years back I downsized that heavy board as that band is far less prog. Was stupid carrying it around to hardly use anything off it. So made a little board with LT on and small VL switcher. That was planned a lot more of a short term affair, but actually used it for years. I recently shrunk it a tiny bit more so it fits in the little case (hence wrong pedal switch labels still!). So that looks like this:
LT remote out taps tempo to the modded Quasar DLX, VL Pedal is MIDI controlled again like the big board above. LT also sends MIDI clock to the Timeline in the rack. So with that rack/loom I can use any of my amps, and switch between a little or big board. So all the best ideas of the big board too, but condensed into a mini size.
But recently decided to do more prog stuff again. Thought I'd design a new medium size board to get custom built (although I do all the cabling/programming myself - they can just build me the custom box). But got a little carried away and it got big (by normal standards). Still a lot lighter than even the empty case of the old huge one though. But this baby is great. Does nearly everything of the old board, but far more portable. It makes a huge difference. So that, which again just plug into the same rack, looks like this:
Already gigged it friday (although some of the wiring is still a little untidy). It's great. Also has 2 amp outs, and obvs the PBC will flip phase on a preset-by-preset basis, so I can use 2 multi-channel amp heads and them always be in phase (as well as iso for the second amp).
So that's where I am at the beginning of 2024! Always got the rack with me so have delay and reverb and tidy power and loom to the pedalboard, can use any of my amp heads, 2 if I want, and can take either the lightweight board for straight up rock or simple stuff, or take the "Board of Fun", for all the swirly, spacey, filtered, synthy, wobbly, arpeggiated, or fuzzy sounds too.
